Anyone used the Arnworx Boost pressure tester
Has anyone used the Arnworx boost pressure tester?
http://www.titanic.co.uk/cgi-bin/gal...7&intReqGall=2
I am using it to check for any boost leaks. I don't think I have, and I make a full 18psi with no problems, but at a recent Dyno the AFR graph showed me to be pretty rich. Fuel pressure is 3 bar and I'm using the Guru chipset
I have connected the Arnworx to the intercooler as pictured and used a spare tyre, an air compressor and a LARGE stirrup pump to pressurise the system. However it doesn't seem to pressurise at all. I can even pull the pipe off banjo bolt while pumping and no air comes out. What am I doing wrong? Its almost as if the intercooler is totally blocked
