Anyone in Indy have air tools and a compressor? THANKS RICK!
That I can borrow for a few hours?
My last mechanic evidently liked to use airtools to tighten these bolts. Regardless of how hard try, I can't get the starter bolts to come loose. I'm using the large socket drive and a mallet with no luck. I'm working this thing hard enough that I (amost) feel like the car is coming off the jacks.
I've PB Blasted and Wd-40'd the fu*k out these bolts and punded them for two days.
Any help is greatly appreciated!
Dan:
I found my impact wrench did little to help remove the exhaust bolts. David and I put 220 pounds on them and only accomplished beating the **** out of the socket. Your best bet is to keep applying brute strength. I got one of those bolts loose by having my son push with his leg on a beaker bar from one side of the car, while I pulled on it from the other. Good luck.
Dan, I almost bought a compressor last week, but I didn't get one. Sorry man. When I get you, will be more than welcome to use it, but I won't get it for another week as I will out of town this next weekend.
I would try heating it up with a torch and using a long pipe on a breaker bar.
Thanks for the thought, Max!
I've been looking at compressors and air tools but just don't have the money yet. I need to get some before too long.
I've thought of using a torch also, but am a little sceptical about flames under the car.....
Originally Posted by ehall
are you still working that starter bolt? if so, gonna be hard to fit a pipe, but air tools shuld do it. goodluck.
Daniel,
I've got both & am only about 15 minutes from you and would be glad to help out.
Is the car still rolling? If so, you could swing by & we could knock them loose & then gently tighten so you can get back home & finish your project. If the car is already up on blocks/stands, I can pile my stuff in the back of my truck & swing by.
I work for beer...good beer!
I've used acetylene to persuade a lot of bolts under the car. It is safe if you're safe, but if you've got an impact gun handy, I'd give that a shot. I've got a small commercial compressor and some air tools, but probably not the power you will need. Nevertheless, if you need a hand, let me know. In this heat, I work for water...lots of water.
Daniel,
What's your schedule this week? Monday/Tuesday are pretty crazy for me but Wednesday-Friday I could do it - after work hours would be great.
Just let me know - will be glad to help out.
Rick
Rick
I knocked off work yesterday afternnon because of the heat and guests.
I plan to try it again tonight.
Rick, if it doesn't come off by Wed, I think I'll take you up on that offer. I'll come up with some good beer if it comes to that. I get home around 6pm everyday and can flex a little. I'm off all day Fri.
Mike, I don't know how easy it is to drive over with traffic, but if this doesn't work today I may put out a Mayday message.
I appreciate the offers of assistance!!
I want to throw out a big public thank you to Rick. He came over with his compressor and managed to get 2 out of 3 of bolts. I'm going to have to cut one of the starter bolts (the one that that has the head forward) tomorrow.
Thanks, Rick. Beers on me!
