Zeitronix wideband
Zeitronix wideband
Hello all,
I was planning to buy the Zeitreonix wb02 kit. I need to know how difficult is it to install. Also I was planning to buy the EGT and boost sensor. If anyone has installed those as well I would appreciate the feedback.
Also if there are additional costs of owning it I would like to be made aware of the same.
Finally, if some of you had it professionally installed how much did that cost as well?
Thanks in adavance for all your feedback
http://members.rennlist.com/tom86951...nd%20wires.htm
Additional costs would be the welding for the bung in the cat pipe I guess. Other than that, its a very nice unit.
If you go with the EGT (and you should do, btw) you need to weld a bung for that one to. You should do that when the exhaust manifold is of the car, but can also do it while its in the car! (difficult though) The rest of the install is very easy! Recomend you to go with both the EGT and boost unit for logging possibility later!
