Please help. Vitesse Chips
I bought what I thought was a set of Vitesse Chips and an accuboost off of ebay. I am replacing an old set of Auto Authority chips. I only received one chip, that says AFM Vitesse Racing. Was I supposed to get a KLR Chip as well? Please help. Do I use the Factory KLR chip?
I am pretty sure the only thing the KLR chip will change is when the CV controlls the WG. However, since you will be using the accuboost, you will be deleting the CV. So, you should be okay.
You are fine. We no longer supply a KLR chip as you must bypass the CV, so any KLR chip will work with our DME chip.
