Where does the throttle body leak?
My inttake is pressurized because I am looking for leaks. I can hear it hissing near the throttle cable but can't see any bubbles when i spray it.
1 Post
I tested mine a few days ago. I have a leak from one of the seals/orings on the "rod" near the spring.
The amount of leakage varied in relation to the angle of the throttleplate.
I ordered a reseal kit from arnnworx.
This is exaclty where I found mine to be leaking just this morning. I had to replace the large o-ring seal that was leaking badly, still heard hissing, found it to be leaking on the "rod" right by the spring, guess it's a reseal kit for me also.
My guess is that the throttle shaft seals (I don't think the stock ones are O-rings) have a normal lifespan of 15 years or so. It seems that most 951:s need new seals.
And since the seal kits are cheap and the work involved in changing them is not that difficult I suggest changing them just in case.
The seals in mine broke up into little bits when i tried to remove them and it was a PITA getting all the bits out, i would imagine that most are hardened like this now and sealing very little
