Piston Education Needed
The picture below shows a Tom C 105mm piston on top and a Mahle 104.5mm piston on the bottom. I was trying to measure the piston to cylinder wall clearance for the Tom C pistons and discovered that the pistons are not round, as shown below. I thought that was a defect, so I measured a Mahle piston (also new) and found that it was also not round. Both are wider on the diameter parallel to the piston pin, and narrower across the pin.
1. I assume this is done on purpose? Why?
2. Assuming this is by design and normal, which diameter do I use to measure piston to wall clearances?
3. My bore measures 4.157 inches (105.588mm). So, if I use the 4.155 piston measurement below, I get a difference of .002 inches. Splitting that difference between both sides of the piston, I think that gives me a .001 inch clearance (as specified by Tom C). Right?
The area around the piston pin has more material, thus it expands more when heated. When the engine is warm, the piston will become round. As Dan said, you take the measurement perpedicular to the piston pin (largest one).
Not sure about the clearance numbers, I had a machine shop do that for me. Hopefully somebody will chime in.
Well the factory manual and tech spec book confirm to check the clearance perpendicular to the pin. (The tech sheet that came with the pistons just say to measure at the bottom.) The piston supplier listed .001 (.025mm) clearance, so it looks ok. The cylinders were bored for these pistons, so they should be right, but better safe than sorry I figure.
"Splitting that difference between both sides of the piston, I think that gives me a .001 inch clearance (as specified by Tom C). Right?
no, you dont split the clearance- the clearance is .002.
How was the bore measurement arrived at, Tom?
Can you point to the reference that says you don't split the clearance dif? I don't see in the Porsche manual, perhaps i missed it.
Tom you are correct about measuring the bores, the T-bar is going to cut it. I had to use a Cylinder Bore gage.. you can pick one up at Enco. As you measure 0.0005" resolution you notice changes throughout the depth of the bore.
I am still curious how they measure pistons for advertising purposes. I note that neither my Mahle 104.5mm pistons or the Tom C 105mm pistons actually measure out to those diameters, assuming I calibrated by mic properly.
Tom
Are you sure you are not misreading those tollerences? I remember them as .0008" - .0032". I may be mistaken, but I dont have any 944 manuals at my work, oddly enough. .008" is sloppy for sure, even by Detriot standards. Even budget forged piston (lots of expansion) companies spec .005" as their "high" in terms of piston/cyl. tollerence for blown applications.
As far as buying a gauge, one option is to drop off the case @ a good machinist (emphisis on "good") and have them handle that step for < $100. Not a bad idea to have machine work verified by a third party. They have the expensive measurement devices (bore gauges that have .0001" accuracy), know how to get accurate readings from them and real-world advice on things like piston clearance and how to arrive at accurate measurement information. They might not have specific knowledge of Porsche things, but I'd trust them before I trusted advice I got on this board. I think you may find the .001" can be easily accounted for in measurement innacuracy, at least a portion of it.
In regards to "where do I have specific info. . . not splitting the dimension", I hold this truth to be self-evident, but you are a good man for testing the source.
I just asked The Racers Groups' cheif engineer Mike Fox and he concurred - the difference between the piston and the hole IS the tolerence. He is arguably the best GT3 mechanic in the country and pretty trustworthy as a technical source, IMHO.
Tom
Thanks for the clarification on clearance.
Tom, I went through a similiar exercise to accurately meaure bores and pistons.. drove me nuts. On the Mahle, at least, the shape profile is round on top and ovalizes as you travel down to the bottom of the piston. The round part was like 0.51mm smaller than the bottom (where you're suppose to measure). The bore was also not perfectly round (larger dia parallel to the pin and smalled dia perpendicular to the pin).. opposite of the piston. When looking for a clearance between 0.0003" to 0.0012" (0.008mm to 0.032mm), it felt like splitting atoms.. my readings jumped around.. then you factor in the Piston the coating which isn't perfectly even at 1 ten-thousands of an inch.
Just an update for those on the edge of your seats. I got a dial bore gauge from Summit, and re-calibrated my micrometer. Also bolted the girlde on and measured on the pistons and the bore where specified in the manual. The result is 4.132 bore on all cylinders (round) and 4.131 on the piston skirts (measured at the bottom across the pin) -- my earlier measurements were off becasue (a) the snap gauges are nearly impossible to center in a bore like a dial bore gauge, and (b) the anvil in my mic was not seated all the way. So, I'm content now that my clearances are set as specified by the piston supplier at .001" or .025mm. Stay tuned for bearing clearances.
