Engine Assembly Parts Prep
What is the best thing to use to clean freshly machined parts, such as the crank, block, etc. They are clean of course, but I want to make sure all the machine residue and grit is gone. WD-40?
"Acetone is good, xylene is better"
I have a gallon of Xylene if you want it Tom
Regards
Ed
Regards
Ed
The specific gravity is higher - so you may be richer, slightly. I have never made any afr adjustments with it up to 40%.
The energy and flame speed are very high, yet the 944 stock ignition system does not have a problem lighting it at above normal cylinder pressures...
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
If you cant find it at the paint store they carry it at Home Depot 10 bucks a gallon
regards
Ed
btw I found gasoline to be a great cleaner ... Just dont get it near a flame
Also a **** load cheaper
regards
Ed
