Parts back from the Ceramic Coater
Drive-by provocation guy
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
Here. This is headers, crossover, downpipe and exhaust. $280.00
Thanks Brett.
http://www.hyperkote.com/
They are right here in Orlando. Actually, right hext door to the guy that did my 3" custom exhaust.
Dropped it all off on Monday and picked up today.
Get it all back to my mech, that is finishing up the rebuild, and hopefully be back on the road in a week or two!!!!!
Yeah, from my research, it may not have been wise to put a heat barrier all over the intake manifold. Your intake manifold should work to dissipate heat. By coating it with a thermal barrier you will trap heat as Jim described.
Most people suggest either leaving it as is or applying a thermal barrier to the underside and thermal dispersant on the top side.
Looks good otherwise.
Question: why wouldn't the intake coating act as a heat barrier..if it's just done on the outside, which most intakes are.
Mine is done in Jet Hot 1200, outside only, and I've got temp data, before and after, that indicates the runners average 18-22 degrees cooler, the flats between only 10-12 degrees cooler. No I don't have any data from inside the intake but wouldn't it seem that the coating acts to prevent heat soak?
On a related note, would painting the intake manifold black cause any additional heat issues?
Todd - those coated parts look awesome! Be sure to post pics when you have them in place
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
E.g. an intercooler is most efficient when painted black.
