Put Red Line NS in LSD by mistake
Old 06-12-2005 | 09:12 PM
gstreev's Avatar
gstreev
Unhappy Put Red Line NS in LSD by mistake
My mistake I put Red Line 80/90W NS gear oil in my LSD Tranny,
it seems do drive OK. Should I add an LSD friction modifer, or drain it
and put in the non NS fluid. Has anyone use AMSOIL gear Oil?
Old 06-12-2005 | 09:29 PM
f1rocks's Avatar
f1rocks
Call the Red Line Tech number tomorrow, they are the best for answering this.
Old 06-13-2005 | 12:14 AM
Zero10's Avatar
Zero10
I am curious on this as well. The PO put in Swepco 80/90W, but I have a guard LSD unit in my transmission. I guess it's not quite the same, but same general idea.
Old 06-13-2005 | 12:42 AM
KuHL 951's Avatar
KuHL 951
Hey Man
If the Guard is like the Quaife or Torsen style LSD (mechanical , no discs) it won't matter. Friction modifiers are usually for disc type LSD's only. I'm not that familiar with the Guards but I believe it's a Torsen style.
Old 06-13-2005 | 03:03 PM
Zero10's Avatar
Zero10
gstreev, I forgot to mention, I ran Amsoil 75W90 in my N/A transmission, it felt like a whole new transmission. Couldn't be happier with it. Very impressed.
KuHL 951, I will have to look into what type of LSD it is, but I hope it's a torsen style unit.
Old 06-14-2005 | 11:20 AM
gstreev's Avatar
gstreev
Does anyone know if the LSD in the 89 used Discs or is mechanical, I think it uses discs though.
Old 06-14-2005 | 11:42 AM
KuHL 951's Avatar
KuHL 951
Hey Man
Conventional discs if it's OE, you will need the friction modifiers.
Old 06-14-2005 | 03:49 PM
Sam Lin's Avatar
Sam Lin
I run half 75w90NS in both my factory clutch-type LSDs. They're so worn they don't need the friction modifier helping slippage.
Sam
Old 06-14-2005 | 05:33 PM
APKhaos's Avatar
APKhaos
Which Redline product is best for the factory LSD - '89 vintage?
Old 06-14-2005 | 05:38 PM
Sam Lin's Avatar
Sam Lin
If over about 30k miles, I'd recommend what I run: half 75w90NS and half Heavy Shockproof.
Sam
Old 06-15-2005 | 08:47 AM
jerome951's Avatar
jerome951
Tony, most people I've talked to recommend either Redline 75-90 (?) w/ friction modifier or Swepco 201. I use the Swepco (it smells like dead fish, though). I think OG now has the Swepco, and I know they have Redline.
The Swepco is a little stiff in cold weather until it warms, but that's not a concern for your use.
Old 06-15-2005 | 09:19 AM
special tool's Avatar
special tool
For anyone reading this who might think it doesn't make any difference - let me tell you.
I put lightweight shockproof (blue) into my rebuilt S2 LSD - it would not go into first.
When I put the MT90 in, no problems at all. That's all it was. These things are sensitive to the oil.
I just happened to have the blue from a dog tranny, and figured I would try to cheap out............. WRONG
Old 06-15-2005 | 05:43 PM
APKhaos's Avatar
APKhaos
Good news - thanks!
I bought Redline 75-90, which has friction modifiers. Their 75-90NS does not. Their blurb is ambiguous, in that it says that the friction modifiers [good for the LSD clutches] may be too slippery for good synchro function. Confusing, but sounds like slippery stuff is the right stuff after all.
Old 06-16-2005 | 08:22 AM
jerome951's Avatar
jerome951
Well, if the clutches don't lock up properly you can always drain and refill w/ the other variety. Luckily it's not a tough job.
Then again, I might be feeding you false information in an attempt to slow you down... ;-)
Old 06-16-2005 | 11:34 AM
APKhaos's Avatar
APKhaos
<snip> Then again, I might be feeding you false information in an attempt to slow you down... ;-)
Doh! You mean that email you sent with the formula for transaxle fluid of 25% balsamic vinigrette, 25% molasses, and 50% diesel fuel was a trick?? Damn!
BTW Jerome, you really need to run some NASA races this season. Hyperfest at SP 16 July would be a great start. C'mon.....you know you want to do it.
Quick Reply: Put Red Line NS in LSD by mistake
