Need help ASAP! Q about mounting recaro seat
So a local shop loaned me a recaro sport so I could see if I wanted those vs the speeds.
I have the stock drivers seat out and I want to transfer the stock 3 point inboard belt receptacle over to the recaro slider. Easy enough, right? Wrong!!
There's no spot on the recaro slider to mount it to! No tapped hole, no bracket, nothing. Of course the stock bracket is welded to the stock slider.
So my question is, how did you guys get that stock receptacle mounted to your aftermarket seats? Are there a specific set of recaro sliders if you want to use the stock belt? Or do you disassemble the stock slider to use that rail with the recaro seat?
Problem was, they were the wrong angle/length and interfered with the movement of the seat fore and aft on the sliders. My shop did a little modification/welding to the PAR-supplied brackets to make them the right angle and length to work. They did a slick job, but it ended up adding several more hours of labor making the job a lot more expensive than I had planned on.
If you can find a current Recaro seat that provides a more direct bolt-on I'd recommend going with that model.
There is a Porsche angle bracket that will fit under the rear mounting bolts on the tunnel side. Don't have the part number here, but I believe it's a 964 part. You can do a search, or someone here may know the part. It fits with the Porche race seat to allow the regular seat belt as well as a harness.
