Piggy back and wb02
Old 05-29-2005, 06:35 PM
cgmonster
cgmonster's Avatar
Default Piggy back and wb02
Hello all
I am interested in installing a fuel piggyback and a wb02 sensor. Any recommendations?
If someone is interested in sellling theirs I would be happy to consider it
Old 05-29-2005, 06:41 PM
Ian Carr
That Guy
Ian Carr's Avatar
Vitesse for the piggy back and zeitronix for the wb02 and datalogger.
Old 05-29-2005, 08:22 PM
Ski
Ski's Avatar
LR Mafterburner + UEGO WB, they do a kit price
SMT6 + UEGO or Tech Edge or Zeitronix
Old 05-29-2005, 08:30 PM
hally
hally's Avatar
i went tech edge http://www.wbo2.com/ an eprom burner instead of a piggyback http://xtronics.com/memory/EPROM.htm.
A bit cheaper and you end up with less electronics in the car.
Old 05-29-2005, 08:54 PM
david fracolli
david fracolli's Avatar
Hally, that is assuming that someone knows how to and what code to change on the eprom.
Old 05-29-2005, 09:01 PM
hally
hally's Avatar
The Montronic Editor is free and illustrates the location of fuel and timing maps, download it here:
http://www.mskar.org/dme_download.html
Just like you would with a piggyback, start with small changes.
Old 05-30-2005, 10:21 AM
Dark Lightning
Dark Lightning's Avatar
Hally, where do you order chips and what brand/model/type?
Thanks for the burner information. Did you need or do you use any accessories?
Old 05-30-2005, 03:18 PM
Bri Bro
Bri Bro's Avatar
http://www.futurlec.com/
Do a search for 2732 or 2764 ( Newer DMEs used the 2764). Around $5 each.
Old 05-30-2005, 04:46 PM
Dark Lightning
Thanks. So for a 28pin DME you'd use 2764-200ns?
Old 05-30-2005, 08:44 PM
hally
hally's Avatar
Beab951, did you mean 27C64, or are the 2764 eproms equiviliant, anyway the ones i used were 27C64G and came from JDR (28pin). They had a programming voltage of 21v and struggled to get them to program after about half a dozen erases so there are probably better choices, still with 3 of them that was plenty of iterations and i got the job done fine. At the end of the day go with Beabs advice, he knows electronics and helped me out researching the 27C64G at the time.
Old 05-30-2005, 09:00 PM
Bri Bro
Bri Bro's Avatar
The 27C64 is a CMOS version of the 2764 memory IC. Both the 2764 and the 27C64 will work. The 27C64 has the advantage of using less power and has a lower programming voltage (12.5VDC). The link to futurlec has both of them in stock. Given a choice, I would pick the 27C64.
Old 05-31-2005, 11:22 AM
Dark Lightning
Rephrasing my old question, do you recommend the faster chips vs. the 'slower' chips? In the case of the 27C64 we're talking 120ns vs 150ns vs 200ns, all of which are damn fast and probably more than the DME requires.
Edit: And what about EEPROM options?
Old 05-31-2005, 12:00 PM
pikey7
pikey7's Avatar
Way to hijack a thread guys!
@ cgmonster, I went for the LR mafterburner and uego WBO2 and I'm happy, except for the one drawback that I can't datalog boost too. It'd be nice to be able to show that against the other features the Mafterburner has to offer, but it doesn't make it any harder to tune.
Old 05-31-2005, 01:31 PM
Kool
Part of the IN Crowd
Kool's Avatar
Once you have a piggyback computer is it even necessary to burn different chips?
Old 05-31-2005, 01:45 PM
Dark Lightning
I think the conversation went from 'what piggybacks are good' to 'how to not need a piggyback'.
Mark - Piggybacks are good, burned chips are better.
Quick Reply: Piggy back and wb02
