HELP :( Car only runs smoothly without TPS ?????
Old 07-13-2024, 01:22 AM
st0ppy
st0ppy's Avatar
Originally Posted by AlexE
Heheheheh J Chen.......... Well I never said it was a good solution.
EDIT: I am a goof. Yes you are right........So at least I should plug the holes for now!!
We have other dilemnas. THe car runs perfect like this. YES its weird.
The question that needs to be solved is WHAT else does the shorting out of B and C do????
The miniute I remove the wire it goes haywire....... roaming idle ...leaning out....... ( with or without the ISV in place so your point is a good one so at least for now I will cap off the intake and intercooler pipe side)
Hi there!
Bringing this back from the dead but I am running into what I think might be the same problem with my 951. Sputters and stalls out with TPS but once I unplug runs good ( minus the reduced boost of course) .
​​​​​​Did you ever actually solve this? What was this B C jumper test you ran? Would love any help.
@fast951 if you have any troubleshooting docs would love to try those out. I am close with the PCA UCR 944 SIG here so I know many would appreciate more knowledge wherever we can get it
Quick Reply: HELP :( Car only runs smoothly without TPS ?????
