OK then, how good is the t04b?
My advice would be to not run with the #6 hot side at all... That wheel creates too much back pressure at higher RPM's. If you do anything other than stock (ie. want more HP) then don't use a #6 wheel. #6 wheel is very streetable with the stock KKK turbo, but for larger power applications, it is impractical.
Well I do still have the k26/8, but I don't know what condition the turbine is in. ( I do know what condition the bearings and seals are though!
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Anyway, I really can't see me pulling the turbo and getting it rebuilt with a #8 just yet. Would a 3" downpipe and front section help with the back pressure? Again, not something I was planning on just yet, but it's on the never ending list...
Regards
Graham
'88 Turbo S
Don't know if this helps or not. I had my B upgraded to a .57 trim and within two months I had blown up the center section. I believe the problem was back pressure. I had the hotside upgraded to a #8 and now the car feels much stonger as if it was opened up in the top end. There is a lot less back pressure. Spoolup is comparable to your k26/8.
You can measure your back pressure by routing a hose off of the factory test tube that is tapped into the crossover pipe. Just plug in a pressure guage. Ideal back pressure would be a 1:1 ratio, but a few pounds off isn't bad.
