What are the different kinds of headgaskets out there?
O-rings are copper and the joints - they are toward the exhaust head stud for that cylinder. I am taking my time building a spare engine: block is done, pistons are coated, bearings are teflon coated, rods are at EBS have the oil shed coating applied.
I don't know if its still true, but when I spoke with the engineer at Cometic (who makes the MLS gasket that's sold by several vendors under their own names) they had two versions, one for use with o-ringed head or block, and for non-o-ringed use. The difference is a slight thickening of one of the metal layers around the cylinder wall that kind of acts like an o-ring for non-o-ringed engines.
When I bought from Cometic, they asked which one I wanted. They will also make them to any thickness and bore diameter you want.
I'll second the statement that this gasket is best used when both the head and block have been freshly surfaced. It is not a cure for a poor seal (AMHIK). It has no real advantage over stock or WFR gaskets for stock applications.
Pelican Products has a good price on the WFR gasket.
Jon.
Jon.
Originally Posted by Oddjob
I have heard of the MLS gaskets on rennlist, but have not come across anyone that is using them in the PCA Track/Club Race community (not that they are not used, just have never met anyone who is using them).
Yes they know Evan, but there have a been a couple of those gaskets cut "as needed" for special builds - custom diameters and thickness, especially for the 2.8 stroker and the 3.0L turbo that's being built at the moment. Tom had the 104.5 turbo pistons the other day at Hallett before they went to the coater. Myself and Jim were the first to show him the Cometic.
