OK my first venting post !! Cycling valve mount. WAFJ
Originally Posted by Crazy Eddie
Damm Tom
That picture makes it look so easy to get to
That's because its laying on a freakin' towel
thanks for the post Tom
The PET Steve sent confirmed what I thought that it's Oringed and bolted in
I assume once you pull this you have to replace the O Rings ?
The one thing that is missing is the PET for the cooling system part
I will need that one. There is a gasket behind that coolant pipe comming out of the head ...
Regards
Ed
Regards
Ed
The neck thing sits against the head with a gasket, and the CV bracke tlays over the neck mount thing, such that the two bolts you see hold both the neck and the CV mount in place. If you want to remove the CV bracket, you should be able to pull those two bolts and remove the CV mount (without dislodging the now unbolted coolant neck thing) and then just put the bolts back in to hold the neck to the head.
I did remove it but it looks like I should replace that gasket
You should see what a PITA it is to remove those two bolt w/o removing the oil filler tube
The front bolts with a socket on it, hits the OAS and it has to be turned by hand
slower that removing the last bolt on the X over pipe that you have to get from the bottom of the car
The bolts are pretty cruddy looking as well I understand from a previous that someone said to add washers because the bolts would be too long
Go to bed everyone !!!
Regards
Ed
So I need the part # for that gasket
Regards
Ed
as well I understand from a previous that someone said to add washers because the bolts would be too long...
AAH It was you Eyal
Sorry
AAH It was you Eyal
Sorry
Eyal
I will send you the info on the parts that are needed... Gaskets, O rings, bolts, ect
regards
Ed
regards
Ed
Regards
Ed
Regards
Ed
Originally Posted by Eyal 951
PLEEAASE remember to shim those bolts when you put em back, I didn't, now I have head work and a new HG.
~Eyal
~Eyal
Why am I not surprised !!
Its like Parts Heaven at your house !!
Thanks Bud
Regards
Ed
GO TO BED !!
Regards
Ed
Regards
Ed
Yup youll need washers if you get rid of the CV and its mount.
UAE Rennlist Ambassador
but does the top of the AOS come off and if so how ?
Coutesy of Mr. Bruce with a little time and patience!
Hos -- if I recall, Porsche does not sell the big O-ring needed to reseal the top as a separate part. I think it was Scott Gomes who had sourced the right o-ring and is willing to sell them to those in need.
I thought it would come off but I didnt what to take a chance breaking it
Who is Mr Bruce ?
How is it removed ... Push down and turn ?
Thanks Hos
theedgeThat gasket comes with headgasket kits as well.
928.106.197.04
Thanks Brian
regards
Ed
Who is Mr Bruce ?
Thanks Hos
928.106.197.04
Thanks Brian
regards
Ed
Ed, the reason the head came off is because i did not shim the bolts. I tried the first one with caution, and it went in and didnt bottom out. So the second one I assumed would do so as well. I jusr ran it down quickly and it bottomed out and snaped. So now i had a broken bolt in the head, sitting pretty much flush. I drilled it out, tried to EZ out, didnt work cause its too tight in there. I i just drilled the entire hole. I went to retap. and the TAP snapped in the hole! So the head came off... At least now I have some nice porting and tastey valve work with a new WF hg!
