logging ZT-2 to multiple sources, DL1/Tec3
Hi,
I am running the output of the ZT-2 (white wire) to the Electromotive TEC3R, I would also like to log wideband in the DL1, since it goes right to a compact flash and doesn't need a laptop. Has anyone output the signal to multiple sources? Is there a voltage drop that will affect the signal?
I would also like to split the map sensor between the tec3 and the DL1, any issues with this?
Thanks,
Andrew Wojteczko,
Auto Analyser Racing
Thanks,
Andrew Wojteczko,
