Early 944 NA block can be used for Turbo swap?
Old 05-11-2005, 12:28 PM
hosrom_951
UAE Rennlist Ambassador
hosrom_951's Avatar
I believe Chris White did some NA block to turbo conversions, try contacting him (www.944enhancements.com).
Old 05-11-2005, 12:51 PM
Toolmaster
Toolmaster's Avatar
The older block will work fine. You do have to look into the oil passage for the turbo's oil lin e- but there isn't much else.
USe your turbo's head, and oil pan. Use the BLOCK's balance shaft covers. Use all the turbo internals - especially the pistons, and you'll also want to make sure you update the old block if needed with the newer water pump. I wouldn't re-use that anyway.
Pay careful attention to the turbo oil line... It NEEDS to be there.
HTH!
Old 05-11-2005, 01:09 PM
Jfrahm
Jfrahm's Avatar
Yeah but check the tolerance group of the pistons, they must be the same if you want to put the turbo pistons into the NA block.
-Joel.
Old 05-11-2005, 01:10 PM
eclou
eclou's Avatar
Received 1,227 Likes on 599 Posts
Tolerance group info is stamped on the top of the piston IIRC
Old 05-11-2005, 01:37 PM
gcb951
gcb951's Avatar
To everyone,
Thanks for all the great info and advise. I will post pics soon of how the project is coming along.
Greg.
Quick Reply: Early 944 NA block can be used for Turbo swap?
