Pauer Tuning Fuel Line Question
Those with the Pauer Tuning fuel lines: Does the Pauer short line (fuel damper to fuel rail) follow the same routing as the stock Porsche line or does it go some different way? In other words, is there enough room under fuel damper for the SS fuel line to bend (when connected with a 90 degree fitting) without kinking or running into other obstructions? Any pics or Pauer Tuning instruction copies would be appreciated.
(Trying to finish this nightmare DIY fuel line project--Anyone considering a fuel line project, just buy the premade Pauer or similar. Doing it yourself will NOT save you a f**king penny and will shorten your miserable life by about 5 years! I will NEVER buy, touch, or even look at another SS line without getting nauseous. Haven't these hose designers ever heard of nomex or carbon or anything other than braided steel. I'd rather my car caught on fire and burned to the ground than have deal with these fittings, lines, adapters, JIS, NPT, UNF, industrial supply people ever, ever again!)
Thanks, Derek, that helps a lot. I figured it must go that way but wasn't sure if the bend would be too tight. I guess it's right at the limit for bending but good to know that going that way is possible.
UAE Rennlist Ambassador
Sorry
Derek: Where did you get the fire sleeve from? do you know if it is fiber glass or what is the material? How much did you get (3 feet, and what ID).
Sorry guys....
![offtopic](https://rennlist.com/forums/graemlins/offtopic.gif)
Sorry guys....
For what it's worth, I've replaced a lot of my other lines with Parker's Jiffy hose using push on fittings and they work great. (Power Steering reservoir lines for instance). And it's JIC not JIS, JIS is for Japanese vehicles. The industrial supply guys can be a pain to deal with, the catch is that you have to know what you're looking for and "speak the lingo" somewhat since they're usually pretty busy. For fuel lines I'll probably just build my own because however much the pain it is, and despite the fact I won't save any money, I'm a do-it-yourselfer to a fault. (Probably why I have a big fat copper bus bar in my electrical system for instance.)
I'll edit this if I can find a P/N for the non S/S braided stuff. It's designed to be a direct replacement for braided S/S as long as it doesn't have to meet Mil-specs even though aside from the material not being S/S it actually is as good or better.
Ok I found it, it's Earl's Prolite 350 hose. It's not kevlar on the sheath, just black nylon braid which is disappointing. I'd probably stick with the stainless for fuel lines in our car just because of the proximity to exhaust parts even if you route it along the firewall. It would probably be ok with firesleeve on it I'm sure but better safe than sorry. But for anything else I'd say it's not a bad way to go, you still get the benefits of reusable fittings vs. proprietary or hard to find ones and it's a lot easier to work with I'm sure without the steel braid.
Rocket Scientist
Originally Posted by hosrom_951
Sorry
Sorry guys....
Sorry guys....
I bought 2 3 foot packages and that was more than plenty for both lines, although I couldnt put the one side on because of the SS braiding.
