Testing the Tial?
One thing I did was to apply pressure to the side port to see that the WG valve opened. I used a simple bicycle pump and teed in a pressure gauge to measure the pressure at which the valve opened. The pressure that opens the valve should closely match the spring rating in the Tial.
The valve pulls into the housing. Reworded: the valve pulls away from the exhaust pipe.
I've never seen a TiAL come off the assembly line dead (heck, I haven't EVER seen a dead TiAL wastegate) but you're more than welcome to check.
Ah ha! In the lower left image, the valve moves upward to control boost:
http://www.tialsport.com/images/38mm_drawing.pdf
