safcII
safcII
can someone that install this before help me with the settings needed to run the car like the sensor type etc.. I have everything wired up but in need of settings because the car is running really rich at idle. it is smoking black on idle.
daniel,
I am not suggesting my settings are correct, but these are current config.
Running a MAF - Sensor Type - Hot Wire
Sens In 1 Sens Out -1
Sens cal
In 1 Out 1
Car Select 4 arrow up
Lo Throttle - 20% High Throttle - 80%
Ne 01 - Ne 12 1000 - 6400
Hope this helps
biggles
Sens cal
In 1 Out 1
Hope this helps
biggles
i finally figured out what was wrong. i had the maf connected up wrong DUH. but i got everything work now. thanks again everyone i will be sure to post up my dyno sheets since i think i am doing doing work for now
