It is alive!!! It is aliveeeeeeeeeee!!
Professor of Pending Projects
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
At 10:15am today my car came back from the dead... oil pressure picked up quickly (several cranks and puring oil in the filter housing I guess helped.
We had an ooooppppsss when I forgot to put two bolts and we had a coolant leak...
Here is the photo of the two bolts missing...
Closer look:
And here is the baby after installing the lights... I need to take it for a short ride and then I will continue to work on it and finish the rest of the body panel installation (I had removed fenders and all sort of stuff because I was going to do a full respray... I guess Edgardo can now take care of that once he starts working on it.
Now time for some
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
![](http://forums.rennlist.com/upload/opps1.jpg)
Closer look:
![](http://forums.rennlist.com/upload/opps2.jpg)
![](http://forums.rennlist.com/upload/itisalive1.jpg)
![](http://forums.rennlist.com/upload/itisalive2.jpg)
![](http://forums.rennlist.com/upload/itisalive3.jpg)
Now time for some
It has been soooo long that I should post some of the history... about three years ago my car developed a leak in the rear main engine seal due to an incorrect installation, by me, when I change the clutch. Seems I did not press the seal all the way in as I should have... anyway... went back in to change the seal and while I was there I decided that I should go ahead and do a few other upgrades... I got a new Turbo from SFR, after removing the stuff to get to the turbo I figured I could change the head gasket with a wide fire item... and while I was there why not .... you get the idea... I pulled the engine out and did a complete rebuild. Replacing even parts that where in good shape... the dreaded disease of "if I know I change it then at least I know it will not break in awhile.... after the rebuild and putting the engine, tranny, exhaust (from SFR as well)... the car sat for 2 years waiting for me to finish the vacuum lines, idle stabilizer installation, and the intake with injectors, etc...
My brother-in-law came here and finished the car over the weekend.
I promised to give it to him if he finished the car... and he did now I have to make good on my offer.
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Originally Posted by Mike B
great progress and a very generous offer! Do you have any other single sisters? Just incase the 964 ever goes under the knife ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
![](http://forums.rennlist.com/upload/side2_copy7.jpg)
(I am keeping the Recaro seat for the 964 or to make a killer play stand for the PS2 and the GT4 game.
![](http://forums.rennlist.com/upload/seatreca.jpg)
The emotion of hearing this puppy come back to life was excellent... anyway... we heard a few exhaust leaks and I had forgotten to put the pipe for measuring emissions back in place and the oxygen sensor was not installed. With that in place all exhaust leak noises are gone.
I do have the coolant pump for the turbo leaking… so I will need a new one unless these can be serviced.
Since we installed a larger turbo we had to cut the J-Pipe to adapt it and that left the diverter valve too far from the IC pipe… so I need a new hose to hook that up.
