How install Elec boost controller
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
Thanks Laust,
Hi guys, i'm new here and I need some help, I just bought a electronic boost controller( GReaddy) and I want install it by myself do you know where I can find some instruction to do it by myself with (944 turbo 86)
Thanks guys and have a good day!!
Martin
Martin
i just got done doing mine a couple of weeks ago. its real easy just tie into the power and ground off the dme and thats about it and run ur vac lines to the boost soleniod.
Just a quick note. If you are running the stock wastegate, set your boost controller to "actuator" (internal wastegate) mode. The reason for this is the stock single port wastegate. If you have a DP wastegate, then run wastegate mode of course.
