Sunroof Problems
Haven't been here much as the car's been running quite well (knock on wood). Took it out of storage this past weekend and my sunroof isn't working the way it should. It has never worked perfectly but now the problem effectrs me driving te car. The roof doesn't shut. It will go up but won't go down. The switch appears to be working as the roof mechanism moves "slightly'
Any thoughts?
Thanks -
Mark
Any thoughts?
Thanks -
Mark
had the same problem...check if it will release & engage for roof removal...if yes then it might be related to your alarm module..mine was!!!...other wise check clarks garage web site for testing the selonoids...3!..there are 2 directional ones by the motor in the boot.
