Zeitronix Question
I was reading on the Zeitronix site that the unit has a simulated narrow band
output.
Can this be used to feed the DME allowing the removal of the stock
O2 sensor?
If so, can I then install the wide band O2 sensor into the stock bung?
Thanks for the clarification.
output.
O2 sensor?
Tim,
The Wideband sensor must be installed AFTER the turbo. I would keep the stock O2 sensor in place, it's faster reacting than the wideband..
No - the sim output is not as fast as the stock lambda.
also - you have to install a second bung AFTER the turbo anyway because the wideband does not function correctly between head and turbo.
