Replacement diverter / bypass valve
#31
Drive-by provocation guy
"Sure, basically not enough air is expelled by the valve "
So running with a lower rate spring would allow more air out and combat this??
#32
If you look at a stock bypass valve next to the evo and figure out a way to open them all the way. You would see the evo opens a lot more than stock also it is all metal so it will not wear and it runs two o-rings for sealing the piston I believe. The evo you can also swap the springs.
#34
Originally Posted by lart951
How come a company with such name as Lindsey could not troubleshoot that problem?
Does affect performance at all?
Yes it does effect performance, it means the turbo is not spinning as fast as it used to when you shift because all the air flowing back through the system forces against the compressor.
#35
#36
Basic Sponsor
Originally Posted by NZ951
Good question, I cant answer it.
"The Lr bov is good for ****". Now I am stuck with 2, and the last one I bought last week from evil944..
#39
Monkeys Removed by Request
maybe I just dont move enough air but, with 300rwhp I have yet to have a problem wtih my lindsey racing evo bov. I will find out if its air in the future when I get a bigger turbo....I really dont forsee a problem at all. If there is I will post about it.
it bolted right up in stock location and hasent given me any trouble.
#40
On a stock car, which I also tested the LR one on, it was fine in terms of compressor surge... this was with my bigger 60-1 HIFI turbo... I would not worry if its on a stock turbo.
#41
yeah which could be the case...I guess we will see. When I get the to4e on there if I get surge I will most defentely post about it and let people know. For now I havent had any problems....even on 20psi.
#45
"When I get the to4e on there"
Be sure to tell me at what rpm you get full boost with that.
I will be getting into touch with don about some stuff and if its even possible to have him do the work. If so I am really leaning towards vitesse chips and stage 3.
If not then its on to lindsey...they always do me right.
