A little question......
Hopefully someone can answer this for me:
I have autothority maf w/ chips, and cat delete. In third through fifth gears, my boost gauge reads 15psi, which is what is should be, and it holds there strong. However, in first gear, I only spool 9-10 psi, and in second around 12. No more than that. I have strong vac, around 15-16 at idle. Is this the way it should be? Or is there some quick thing I am missing?
Originally Posted by J Chen
Boost reading will always be lower
when the engine is lightly loaded.
Is your wastegate shimmed ?
Originally Posted by Eyal 951
Like I said before, get rid of those autothority chips, get a tial, and you should be getting as much as you can out of that k26/6.
~Eyal
~Eyal
