What kind of plugs do you guys use ??
#31
Originally Posted by streckfu's951
![](http://forums.rennlist.com/upload/plugnoflash.jpg)
![](http://forums.rennlist.com/upload/plugsnoflash.jpg)
Have a look on the web, there are charts floating about which show the plug colour and the relative condition.
Its hard to tell from a picture mind.
I thnik that light to medium brown is the appropriate colour that would indicate correct plug tip temps.
#32
My gaps arelittle wide too. I don't know if that will have much of an impact. Any way, they are getting replaced with NGK BPR7ES.
I thought about using the BPR7YES plugs with the V-groove. But I don't think that would help much. They claim it move the spark outward more.
![](http://forums.rennlist.com/upload/ngk24a.jpg)
#35
those photos of the bosch platinum shows exactly why they shouldn't be used. you'll notice that the center 'platinum' electrode has worn away to the point it's recessed into the ceramic insulation.
despite what people say, i think bosch platinum plugs wear out faster than anything else on the market.
#37
Actually, if you look at the website, it shows that it the design. The electrode is recessed inside the insulator.
Link
#38
Basic Sponsor
Link
Link
#40
Encouraged by this thread, I changed to NGK BPR7ES plugs today (old ones were Beru somethings, due for replacement anyway). Also cleaned and re-oiled the K&N filter... and what do you know, the thing just might run a bit smoother. Or then it's just the psychological effect after a small tune-up
#43
Link
Link
they get like that as they get worn.
#44
I know my wastegate is weak and bleeds boost (max is ~13psi before quickly bleeding off) so I don't know how lean it gets. I did post another thread requesting info for a dyno shop that can measure AFR.
I'm thinking of buying chips from Vitesse, but would like to retain the MAF so I'll have to talk with him about that.
#45
I completely forgot about this dyno chart. It shows me going rich as I am losing boost due to a faulty wastegate (getting changed soon). I max at 13psi before quickly dropping...
This is my dyno curve from a few years ago without the weak wastegate without AFR. There's a big difference.
![](http://forums.rennlist.com/upload/dynoafrsmall.jpg)
![](http://forums.rennlist.com/upload/dynorun1_copy4.jpg)
