Rear "Hatch release" motor delete...anyone tried this??
Originally Posted by Mike Buck
FWIW, my experience is with an '88 coupe, 2 '89 coupes, and 2 '91 coupes.
I swear I hear a noise when I turn the key, like a motor clicking and doing some work. If I'm dead wrong, I'll be the first to admit. I wish my car was hear so I could go check for myself.
I think you can just use a hammer.
Apply deliberate but directed force to rear hatch glass*.
*note shield eyes
Now retrieve objects from rear deck.
Replace
Repeat as necessary
I agree...Porsche engineers sometimes have too much time on their hands.
*note shield eyes
Replace
Repeat as necessary
This came up the other day. It was changed in 1988. My 1987 will open with a key.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
I guess some 944/968s came with a solenoid key and some came with manual... MIGHT have some thing to do with the security system!!!!
Ill get a video proving that it work on my 86' with no battery connected if i have to
-Ian
-Ian
My 86 works just fine without the motor....in fact it never had a motor since i've had it. You just need to make sure the hatch is positioned correctly. I have to give it a little pop with my knee under the spoiler to get it to open, as i still haven't gotten it adjusted correctly.
Originally Posted by Asarus
In my 1991 coupe, i cannot open the rear hatch if the battery is disconnected. The key seems to control a motor and not directly the mechanical system...
My -91 S2 needs juice to open. I've had the little lever on the motor break 2 times by now, you have to get in from the front, unclip the trim and pull on the wire that goes to the locks to open the hatch.....
The hatch lock is connected to the alarm system - you can open the hatch with activated alarm w/o any problems.
Tommy
Tommy
They made a change in 1988, before then it was a key that turns a small cam, which pulls on the cables which frees the pins (the knee bone connected to the...). From 1988+ the key is a microswitch. You cant open the hatch without the key.
I did not know that until a few weeks ago, when it came up in a thread. Went to check out some cars and wouldnt you know, it is true. What a dumb way to open the hatch. It could be worse, it could be a Boxster
Tommy
Tommy
I had problems with mine recently. Firstly, the cable snapped near the motor. I made the brass cam to sort that out. Next, the cam on the motor snapped when I manually pulled the cable after my battery had died. Bought second hand motor just for the cam but this broke in my hands testing it. So I made an ally cam and put an ally handle in the mix with a bias to help pull it the correct way.
Like tommye says, alarm system senses the current to the motor and disables the alarm, according to my '89 O&M manual. My alloy (pot metal?) arm broke twice, I cut/ground one out of steel and put some slack in the cable. Trouble free since then.
Lou
Lou
