Needs more cowbell
Spell Checker
Needs more cowbell
Well actually more rear brake and suspension Thought you guys would like this one. Entering turn two at Sebring I believe. No suspension upgrading before the next DE, but I will be getting more rear brake and some brake ducts. So, for those of you wondering what a good upgrade is, bias valve. OK well the file is too big.
I used to have a pic of my 944 up on 3 wheels coming through a slalom... Should have used it as a background before I lost it
Your back end looks kind of high
I have a bias valve on my 951, and it's so much better than without it. I don't know why they weren't standard.
Ive got a bias valve waiting to go in mine. And all new rotors. And Pagid Sports. SS Braided lines are already in
Does anyone know if there is a size difference between 86 951 master cyls and later ones? I read somewhere that 86s had a 17mm bore and later cars had 23 or so, thus a bit more stopping power...
How do i Identify the valve? My rear lock before fronts, but the PO said all he did was LBE and the strut brace. If i dont have a bias valve, I'll have to find out what the issue is. Could be that I just didnt do a good job bleeding the fronts after the SS line upgrade all around.
~Eyal
~Eyal
Mike,
It's the bar of pressure. The 5/33 means that 33 bar of pressure needs to be realised in the rear system till it relieves. Opposed to 18 bar. So, the 5/33 means that the rear brakes harder / longer over the 5/18 valve. Therfore more likely to lock up, but generally the car brakes "better". Can anyone confirm my nonsense?
