You're better off making one, unless you can find an old koklen one. I wish they would sell just those w/o the IC pipes. I am going to try to make my own afm relocation pipe.
I believe the k&n cone showed no gains on the dyno over the stock box, which gets cold air just as the cone in the headlight would. Its obviously your decision, but dyno tests are dyno tests.
The only reason I am doing that to mine is because my new turbos inlet size is 2.75 inches. I hacked up my jboot to make it all work and it looks horrible. Hopefully this will turn out better. Any thought on what a guy should use for metal. Aluminum? Stainless steel?
