Oil Leak
I've just noticed an oil leak coming from somewhere around the oil fillerI think.
I 've just replaced the turbo and have been test driving the car.
While under the manifold I installed an oil catch can. I checked the new lines for the catch can and they seem fine.
The leak seems to start while driving,after parking a small puddle develops
but doesn't get any bigger after setting awhile.
Yep I thought it was related to crank pressure also.
I am using the AMW catch can which has a line to the AOS and a line from the intake so there should be a vacum on the can.
The AOS was not drilled because my understanding is it's not needed if
you have vacum on the can.
The lines I used are smaller than the stock lines because that is what cam with
the can .
Are there seals on the AOS ?
the can .
Oh crapp!!
I guess replacing the seals on the AOS was one of those ...I should while I'm in there......things.
Well I guess I'll pull the intake and take a closer look.
