Please Explain Overboost Cut-Out
#31
Here are the aftermarket chips that were replaced with OE by the previous owner, who was suffering from very rich mixture and unburned fuel...which, in retrospect was likely being caused by the removal of the boost controller by a prior owner.
#32
I think my first needed action has come clear. I should not be running a two stage waste gate without boost control. If this is my situation, the simplest, conservative fix is at hand.
I need to confirm that the current waste gate is a two stage with top port connected to the IC tube by the left hose coming off the banjo bolt T-fitting...and that the side port of the WG opens to the atmosphere via the uncapped blue tube that can be seen under the fuel rail...THEN, the most prudent, conservative, cost effective action will be to purchase the Lindsey Boost Controller, set it to something conservative (less than 15 PSI?) and put it in line between the blue hose and the now-plugged side of the IC tube banjo bolt. This should restore the correct function of the aftermarket WG, right?
This would bring intended mechanical boost control to the current WG with the protection of the stock chips still in reserve for overboost cut off protection. I would be spending $70 on a part at Paragon and adding one pressure line connector to get all this done.
I think this is minimal effort/cost path to correct the current risk of overboost and stabilize things. This is probably what Previous Owner 2 or 3 thought he was doing by rigging up the current situation. But this "atmospheric" fix apparently does not respond quickly enough to overboosting spikes linked to vacuum....needing the assistance of the pressurized side port to get the WG open to respond to high boost. Right?
If this removes the major risk of overboost then I have some time to consider whether I should enhance the boost control system or use the OE waste gate and j-tube in my spares box to go back to factory and put the cycling valve back in play.
#33
Yes that will get the wastegate working correctly.
With the stock chips you must run stock boost. Otherwise the car will be lean
under boost, risking blowing something up.
#38
Originally Posted by Evan70
Things that have been changed on the car:
plugs, wires, coil, cap & rotor, all vacum lines, MBC to EBC, TPS, O2 sensor, AFM, chips.
With the previous chips it would do this in 3rd-5th, and would limit boost to 1.1 bar after the initial cutoff. With the Guru chips, it will now limit to ~1.4 bar and only occurs in 4th and 5th. I have tried lowering the boost pressure, but it takes a HUGE drop to make it eliminate the overboost problem. On the previous chips (Autothority I think) I went as low as 9psi and still had the issue. On the Guru chips I've dropped to 11PSI and don't seem to get the problem, but of course I don't feel like driving around like that so I really don't know if that really does eliminate the problem. The problem is easy to drive around, as it only occurs when going full throttle from 3000rpm or lower in 4th. If I go full throttle right at 3500 in 4th it doesn't have the issue and will pull all the way to redline at full boost.
I just blew the head gasket, so the that's being fixed right now, but I should have the car back tomorrow. While they where fixing that, they finished removing the cycling valve (had already been bypassed). I'm hoping that I might have had a leak around the intake manifold, which will be fixed when it's reinstalled. If not, about the items I've got left to target are either the AFM or the KLR itself. I haven't tried getting the trouble codes, but I will once I get it back.
To me it sounds like you have a major problem with detonation, which is most likely how you blew your headgasket. Keep running as you were and your new headgasket will go in the same manner relatively quickly.
Dal.
#39
The KLR overboost protection mode is the fuel cut off. It's not limited soley for use with overboost situations (can also kick in due to knock/detonation and various other reasons), but sustained boost over the max spec is one of the reasons it can be invoked.
At this point I'm swapping out to some different chips since I don't like the A/F on the top end of the rpm range (13-13.5:1) and putting in some used Vitesse chips. Hopefully those will work a little better, and combined with all the other work that's been done I hope it solves this issue. If not, I'll get the fault codes and see what they say.
#40
All I'm saying is that something else is wrong. If you set your manual (electronic - whatever) boost controller at 11-12 psi and still trigger the fuel cut then there is something else wrong. Solve that problem first, then play with chips.
edit: another thing just occurred to me, how is your AFM? If the AFM values are off then you could be confusing the hell out of your DME.
I'd look at the fuel system - pressure and fuel injectors (pull them and get them checked cleaned at Thompson turbo ($25 each - same day turnaround)).
Dal.
#41
Originally Posted by Porsche-O-Phile
This thread is excellent. Good information - thanks to everyone for chiming in. Does anyone know how the KLR computer determines which cylinder is knocking? I am only aware of one knock sensor, located between the #2 and #3 cylinders. If this is true, how would the computer know which cylinder's timing to retard?
Dal.
#42
My boost isn't fluctuating, it's behaving perfectly normal. The problem is that if I go full throttle from 3000rpm in 4th (or 5th) the KLR kills the fuel pump at 3500rpm. Boost is building normally and the car runs just fine other than that one spot. I guess I should mention, that if the problem is still persisting once I get it back, that I'm already planning on replacing the knock sensor and probably just upgrading to 55lb injectors. From everything I've seen, I'm already getting very close to the limit of the stock injectors, so I'll just put the $100 I'd spend on cleaning the stock ones into some bigger ones.
Also, I did hook the stock CV back up when I first started troubleshooting the problem and it didn't make any difference. That's one reason I'm kind of leaning towards the KLR being bad, but it doesn't make any sense to me why it would only do it at that one point in the rpm range. Of course, another possibility is that maybe there's something rubbing/vibrating somewhere at that rpm that is making the knock sensor think there's detonation.
#43
Sucks. I hate chasing electrical issues.
Good luck.
Dal.
#44
The DME fuel cutoff is an almost violent stumble during a full throttle condition. In the KLR safe mode, the car will only make a little over atmospheric pressure (manual says 1.3 bar abs), but runs normally, just with no/low power. Does your car have both these symptoms or just one or the other?
#45
The initial symptom is a complete loss of power, after that the car will run fine but will start stumbling really bad as soon as it gets sligthly over atmospheric pressure (around 1.1-1.3bar on stock gauge). If I then shut the car off and restart it runs just fine until I duplicate the condition that triggers it again.
