KLR chip anyone?
Well.....
Since the KLR is also listening for detonation (knock/ping), and since you do not "hit the wall" until you turn up the boost, the KLR could be sensing detonation and retartding spark advance.
Just my $0.02
Just my $0.02
Originally Posted by jimbo1111
Update. I did a little digging around an I found my spare ape stage 2 dme and klr chip. I will be trying them out this weekend. Thanks anyway Evil.
Truth be told you really don't need a klr chip if the cv is bypassed. So John is correct.
Would I ever mislead you?
Now if someone could bypass the klr with a piggyback that can retard timing through pin 21 and 32 on the dme. They can run very aggressive timing in the dme chip and have complete control of timing. Without a stand alone. Granted you can only retard the timing but if it's advanced highly in the dme chip. You have complete control. This would be a good upgrade. Remove the klr and fab a plate in it's place for the piggy back and wideband. You will be in complete stealth mode and free up the glove box.
