Odo not working
Hi Guys,
Replaced odo gear, made sure everything was
turning smoothly before reassembly. Installed
gauge pot back onto car but odo not working.
Could not even reset trip meter. I also visually
confirm that the worm gear is in got shape.
So, where do I go from here ?
Before Special, yes I'm aware that you're not suppose
to reset while driving. Took it apart again to check &
everything seems o.k. It was working before the odo
gear went south. Any suggestions ?
It looks like all three items are powered from the same supply.
I have one in pieces at work awaiting a new cam gear. If you don't find the problem before then, I can take a look Monday to see what you can do to test and help find the problem.
I ordered mine from Rennbay, guess I'll see if it has the same problem.
The odo drive motor has a single mount screw at the top. You can try shimming it out a little to gain some clearance.
