Piston coatings
#31
My bill at Lindsey was $160, shipping too. Jim's (jwl) was $224 at Swain all together. The Swain 2.8 pistons are in this:
The lower parts were all cleaned and bead blasted and then heat resistant clear coated only. For those concerned about Jet Hot 1200 coating holding up to the heat, those are the same ones off his 2.5 Vitesse Stage II after 8k+ miles.
![](http://forums.rennlist.com/upload/p4060001.jpg)
![](http://forums.rennlist.com/upload/p4060002.jpg)
#32
Jane Bond 007
Where is the info on this at the Lindsey site? I just went there and didn't see anything. Do you have to personally contact them?
#34
Originally Posted by Zero10
Hmm, I'm a little worried about having my pistons coated now...
Is it possible to get all the remaining coating removed, and have the factory coating replaced?
#35
Haha, that advice comes a touch late ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I bought a set from Ski, they're already coated. However, I have some other parts I would like to have coated with various coatings. Would you reccomend them given any experiences you had with them?
Do you have any idea if the molykote was compatible with the alusil bores? i.e. do you know if you have any appreciable cylinder wear/marking?
#36
I have Darton liners thus the compatibility is not an issue. Becomes a standard Chevy piston cylinder material mix. Like I said the pistons looked very good after about 10,000 miles or 16,000km, so yes I would recommend them for exhaust pipes etc.
#37
There is an article this month in the leaflet formally known as European Car Magazine. It won't keep the Pulitzer front-runners up at night, but worth reading. Bottom line: they test it on a piston with a torch and it proves effective.
