Received my PC'd stuff. Update: Hes going to stiff me.
Originally Posted by Mike Murcia
They probably couldn't polish the Porsche script because of the pitting from sandblasting.
Post pics mate! I would be keen to see their effort. Oh and you took the shaft on the price. It costs peanuts to powder coat. I suspect they were waiting to fit you in a batch with a like colour.
It looks almost black as I said but then when I had it done, it looked almost baby blue
Matt - have you ever painted a house? If so you know that the color on the can is rarely the color on the wall with the exception of white.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
That's bull. If your final cost is going to end up being more than 10% off the estimate, most times they're supposed to call you before proceeding. This is one of the most bogus and unscrupulous things that's done by various shops and it constantly pisses me off to hear about it. There's NO reason for it other than "well, the guy needs his parts back, so let's gouge him for it". It's bunk, pure and simple. You need to tell them (the manager, specificaly) that if there are complications or problems, you expect a phone call BEFORE work is done if it will cause the final cost to deviate by more than 10% of the estimate. Otherwise, what's the purpose of the estimate?
Don't be afraid to either (1) demand they do the work the way it was agreed upon - for the cost agreed upon (it's actually a legal contract if you get right down to it), or (2) turn on your heels and walk out. Seriously. Tell 'em "keep the sh*t" for that price. Yes you'll be without the parts, but you can probably pick up decent used ones for that price.
Blasting (bead or sand) should NOT be done on some parts. I dont know if your cam tower was completely apart but even a tiny amout of grit can destroy a motor. Also the normal blasting media is bead when dealing with aluminum. Just make sure they didn't destory your cam tower by contaminating it.
Good luck and dont lose your head, just make a demand and stick with it.
Matt, actually, before I returned to school I was managing a lumberyard, before that I spent seven years in residential remodeling. If the paint isn't damn close to a sample, either you haven't given it enough coats, or the paint wasn't mixed correctly. Sure, if you're putting white on over brown, it's going to take a while, but with the proper amount of work it can be done. Where this guy went wrong though was by not informing his customer ahead of time that the finished product would be quite different from the sample, which obviously not done. Certainly this wasn't the first time he had powder coated something, so he knew what kind of results he would get.
If he did bead blast the parts. (I bead blast just about everything before coating them) Make sure the parts were cleaned inside and out then blown off. If you can run something inside the parts and make sure there is no grit. Polishing the script is easy. Good luck with everything. Did he use standard powder on your brakes? Most powder ony handles about 350 degrees. It bakes at 400 and brakes run a lot hotter than that under heavy load.
Matt, my point was there are a lot of factors that can determine color. In this case, I think they just shot the wrong one.
After reading all of this I am very ready to go have a talk with him. Thanks for all the input. I will let you know how it goes. And I guess the blue isn't totally baby blue but it is lighter than royal blue. At any rate, it is not what I wanted or even close.
Yep, high temp powder
Ok, well! I just spoke with him. He is going to stiff my ace. Not doing anything. He said he didn't damage the cam tower with the sandblasting. He also said that he did the color I choose. But it looks darker on paper. Then he also said that the price is cheaper than anyones around here. So whatever, I'm going to pay out the ace for the stuff, get it back home and who knows what I'm going to do. All I know is this sets me back at least another 2 weeks on my car which is also being a difficult.
