Attn MAF users
#61
Is it correct to assume that the variable TPS signal to the KLR is used by the code in the KLR to control boost via the cycling valve ie some sort of table lookup based on RPM and throttle position(from the TPS) as well as giving a WOT signal to the DME. I read somewhere that Bosch/Porsche didn't have time to integrate all the functionality required for turbo engine management into one box so they added the KLR and kept the DME essentially the same as it is in a 944 NA
#62
MildMax951
Your assumptions are accurate and are "right on" about the KLR development/functions.
The main function of the KLR is to retard the ignition timing determined by the DME maps
based on the boost (& other variables) being sensed. The 944 functions without a KLR
by just jumping pins 32 to 21 on the DME. Therefore, a non-turbo DME can be easily converted
to a turbo DME by sending its' ignition signal to a KLR & receiving the modified KLR ignition signal.
Nothing really complex about it.
#63
The middle state provides NO useful throttle info (no actual angle) other than not
at idle or WOT, i.e. it's basically useless.
RPM doesn't determine the load. Load is a function
of an independent variable, e.g. 0-5 volt sensor.
Load is purely a function of air flow or air mass flow as used by the DME.
Yes, there's an in between state, but this operation is not a true TPS.
"No. You're basically clueless." - TT -
Now it starts. Can't discuss the issue, so let's attack the messenger. Real Good!
As for the TPS, part throttle is a very very important area of operation for the DME. A street engine spends the bulk of its life at part throttle. It is a very complex area of operation which is why the part throttle maps are three dimensional unlike the simple 2D idle/WOT maps. This area is also where the hard tuning work is done for emissions control.
Back to engine load, since it looks like we agree that MAP does measure load, lets stick to that. Again I pose the simple question:
An engine at 3000 rpm, air flow is 200 scfm.
Same engine at 6000 rpm, air flow is 200 scfm.
Would the intake manifold pressure (aka engine load) be greater at 3000 rpm or 6000 rpm?
#64
I have a question: Can Jimbo scale timing by 37% to match the injectors?
#65
Loren - starting trouble AGAIN!!!! I knew you would do it here, also.
I have your number, my friend. I had it last week. Cut the crap.
Also - TT could build you a 951 DME blindfolded with parts from his toaster, man. Don't you know who you are talking to????
#67
Originally Posted by Lorenfb
Load is a measure of work. Torque is work. Therefore load is a measure of torque
being produced. Rate(RPMs) of work/torque is energy is horsepower.
Again:
Example; climbing a hill @ 4000 RPMs & cruising @ 4000 RPMs, same RPM two different loads.
Climbing a hill requires more torque @ 4000 RPMs than cruising @ 4000 RPMs, thus more
load on engine but same RPM. The greater load (more torque) required more
HP to climb at the same RPMs.
HP = Torque X RPM = Load X RPM
no engine load = no engine torque
Load(hill) X 4000 = HP (hill) > Load(cruise) X 4000 = HP(cruise)
Load(torque) determines charge (energy) input (fuel + MAF) for combustion.
RPM determines rate of charge input. Therefore, load(MAF or a proxy) and RPM
are independent variables yielding an energy output (horsepower).
Again:
Tomas
BTW, as already been pointed out, do a search on TT:s previous post before you question his Motronic knowledge.
#69
When the DME uses the signal from the TPS as a switch (idle, partial, WOT) than a scale between 0 - 5V, would this mean that it's almost impossible to create a chip for a intake manifold with individual throttle bodies?
#71
"Loren - starting trouble AGAIN!!!! I knew you would do it here, also.
I have your number, my friend. I had it last week. Cut the crap." - special tool -
Let's post somthing intelligent and/or make some contribution to the thread
instead of slams or post on the "other" forum with the other zeros!
I've yet to see any real technical knowledge expressed on any of your posts.
Are you capable, I doubt it based on what's been posted?
Again:
The state of NOT being at idle nor a WOT, does NOT provide any info to the 944 DME
as would a true TPS input (0-5 volts) input to the DME. The 968 has a true TPS
which can be used to further define points on a load map based on ANY value between
0-5 volts, not just at idle or WOT. The DME then "knows" what the actual throttle angles
are for ALL throttle positions.
That's the issue!
Again:
That's the issue!
#72
Same engine at 6000 rpm, air flow is 200 scfm.Would the intake manifold pressure (aka engine load) be greater at 3000 rpm or 6000 rpm?
Lorenfb, Answer the question
#73
The state of NOT being at idle nor a WOT, does NOT provide any info to the 944 DME. The 968 has a true TPS which can be used to further define points on a load map based on ANY value between 0-5 volts, not just at idle or WOT. The DME then "knows" what the actual throttle angles are for ALL throttle positions.
The 968 may get an angle related voltage input from a TPS just like the KLR, but in the end it still boils down to (even in the 968 Motronic and every other Motronic I have examined) idle, part throttle, and WOT. Those are the three basic Motronic operational states.
Sticking to the other issue at hand do you believe load is airflow and not airflow/rpm? I see no answer to my previous technical question.
#74
Posted by Slow951: I have a question: Can Jimbo scale timing by 37% to match the injectors?
If TT is correct that load coincides with rpm. Than yes. When a maf meter and injectors are sized 37% larger you expand the 0 to 5 volt signal as well. It spreads out evenly from the center out. That's why the injector duty cycle drops and you could only go up to 72lb injectors. TT is doing the same thing. Just bypassing the afm conversion in the piggy back for a conversion on the chip. Thats why you also can't go past 72lb injectors. Get it john.
One thing TT and Lorenfb left out is that the dme reverts automatically to wot maps when rpm hits 5600. Not only when you are at 66% throttle.
