Question on vacuum line routing after MBC install
Hey guys,
First off sorry for the silly question, but this has me quite confused. I recently deleted my Cycling valve with the lindsey updated kit and I just ordered the manual boost controller. I currently have the banjo bolt off the intercooler pipe feeding to a lindsey boost enhancer and then the line goes down to the wastegate. In order to install the MBC properly I should splice into that line after the LBE to the MBC and then run the other side out down to the wastegate correct? I just want to ensure that I run the lines correctly. Thanks in advance.
Rocket Scientist
No, the Boost Enhancer is also a form of boost control. You must get rid of the boost enhancer and hook your boost controller up between the banjo and the wastegate. Good luck.
