Spray Can Boost builder???
Drive-by provocation guy
![Arrow](https://rennlist.com/forums/images/icons/icon2.gif)
Interesting:
"If you want an even higher initial peak boost value, simply T into the wastegate line a small sealed volume, such as a small aerosol can or the pictured camping water container. This will allow boost to flare a bit, as the can needs to fill with pressurised air before the wastegate starts to move. This can be a surprisingly effective modification - on one Charade Turbo, fitting just the over-boost can was enough to give wheelspin on every full throttle first-second gear change!"
