How do I remove intercooler pastic shroud?
I got the instructions from Lindsey's racing site and I had all the pieces off except for the two bolts holding the plasting intercooler shroud that you have to get at from the front bumper inside the air inlet. The Lindsey site describes them as 10mm plastic bolts but mine are circular with two small notches in them. It looks like you need a special tool to get them out cause I didn't have anything that would work. Anyone know what I need to get them out?
Rocket Scientist
They should be 10mm. Try using some pliers to get them off and replace them with new ones. There are also two above the IC IIRC. Not sure if you need to pull the front bumper off to remove that piece, I remember getting mine off without removing the bumper because I only had have for a header panel vent.
I don't have pliers that are long enough to reach in, plus there's nothing to grip since the bolt's are circular. I need something to fit the two little notches in the bolts, I guess a previous owner switched these for non-standard bolts since no other instruction manuals refer to them. I got the two screws above the intercooler no problem, it's these last two I can't get at.
UAE Rennlist Ambassador
Used a long extention and a soft 10mm socket, removed the two plastic screws and used some soap to "slip" that plastic shruoud out (by wiggling a bit).
Came off in one piece and no problems.
Originally Posted by Peckster
There just might be a purpose for that shroud, such as managing airflow for more efficient cooling. Come on guys, don't work on your cars while hammered.
Originally Posted by hosrom_951
Mines back in, i took of the IC for cleaning (you would be amazed at what 18+ years of exposer does, i even had some bird feathers!)
Mine had the plastic 10mm nuts, just like you find in the wheel well liners.
