Zeitronix photos - everyone likes photos.
True... We'll see what happens, and how much I bring in once its summer, and I can work more and study less. Right now I don't bring it that much.
~Eyal
~Eyal
Originally Posted by Eyal 951
Brian, I'm not sure what you mean... I put the bung about an inch away from the head on the #4 exhaust manifold, ran the wire through a plug into the battery box, through a large plug next to the battery down the side of the dash (kinda hard) and into the zeitronix box.
ehall, I love this interior!
Hosrom, I hear this kind of AF ratio decreases turbo lag!
Andrew, Thanks for the compliment. What do you mean by HU?
Derek, It was actually simpler then it looks. I used this write up to help. http://members.rennlist.com/tom86951...nd%20wires.htm
My install was a little harder as I made it harder on myself by placing the bungs in erginomically hard places...
~Eyal
~Eyal
(why does boost read -0.8??? when i squeeze on the vacuum line it reads 0.
Is EGT "Exhaust Gas Temp?" Why does it read 200* when the car is off? Unless you just had it running, and then shut it down to take the pics, that doesn't make much ense.
the egt minimun on the zeitronix is 200 C so it reads minimum. As for the boost, i pulled of the vacum line from the boost sensor, and it still read the same. I unpluged it, and then number changed to like -0.6 or so...
~Eyal
~Eyal
The reason it reads -0.8 is because you are at a different elevation that the unit was calibrated at, or at least that's my guess.
Is there a way to re-zero it?
All of your boost readings will be 0.8psi low if I am correct.
old thread revival huh...
Kevin, I think I have pics on my home computer. if you pull out the cubby, there is more then enough room for this. its very easy to just push it on.
Zero, so reading say, 16 psi, woul really be 16.8?
Eyal, I was talking more about the backside of the plate itself where you mounted the display too. I wanted to see how much room you have between that and the boost guage.
