Carbon Removal from Pistons?
Old 02-22-2005, 06:57 PM
jasoncoker
jasoncoker's Avatar
Yeah, that is why it should be dull and only used for the thick stuff. I had no big problem with scratching, but I was not pushing hard. It definitely saves some time.
Old 02-22-2005, 07:13 PM
pikey7
pikey7's Avatar
Nylon scouring pad. Or someone actually recommended using a credit card to me once! I can think of better uses...
Old 02-22-2005, 11:49 PM
Mike S
Mike S's Avatar
Tom, Carb cleaner and some brass brushes worked great for me. The brass was tough enough to take it off without scarring up the cylinder walls.
Old 02-23-2005, 12:32 AM
shane rizzo
shane rizzo's Avatar
Take a rag lay it on top of the piston and fill up the holes with brake fluid. It will brake up and remove all the carbon. It will slowely leak past the rings to be sure you drain the oil pan. This will even free up some carbon on the rings as well. Good luck.
Old 02-23-2005, 04:09 AM
jns
jns's Avatar
Tom,
I know your head is off. I was just stating that I heard using ATF to clean off carbon has worked for others. If your head is on, put it through the spark plug hole. If your head is off, put it on top of your piston. The high detergent content in ATF is said to work well. Hope it works for you.
Old 03-02-2005, 04:11 AM
Tom M'Guinn
Tom M'Guinn's Avatar
Thanks for all your suggestions. They are clean enough to eat off now. I did it mostly with Simple Green, Scotch Brite and a plastic toothpaste cap. Wish I had a better picture. They are a sight to see.... I bet there were 2 or 3 cc's on top of the No. 3 pistons, give or take...
Quick Reply: Carbon Removal from Pistons?
