To those that deleted their turbo water cooling.
Can anyone splice of the wire and top part to the turbo water temp censor from their non water cooled cars? or better yet a parts car 951? mine is torn at the base, and I want to fix this. Thanks!
~Eyal
~Eyal
thanks! I'm really not good with this electrical stuff. what should i tell a clerk at the hardware store that will end up with me having the right part in hand? I can solder it myself. (Isn't it scary that I'm going to install my wideband this weekend!)
~Eyal
~Eyal
Luis, he didn't delete the water cooling to his turbo, he's asking for a part that would be left over from somebody else's delete.
Eyal, you need a specific part #, unless you want to take your old sensor in and try to match it (may take a while). I don't have it off hand right now, many of the vendors can provide you one (but with significant mark up). I have very limited internet use for the next 2 weeks or so as part of a project I'm participating in, but if you haven't found it at that point, I could help you out (e-mail me if it comes to that). Hopefully somebody will just post the part # here.
PS: The "change" to another style sensor is usually done for clearance when used on a bigger turbo. Also, you may try modifying a female connector from another application, and modify it a bit, or maybe even a butt connector (sp?).
Ahmet
Ahmet
