KKK A/R rating
From what I've seen a KKK #8 turbine has an area of 8 cm², but which area is that, the turbine inlet or outlet? And how does that translate to A/R numbers?
Tomas
Tomas
TRB0 GUY
Originally Posted by Skunk Workz
It's the area of the tightest point of the inlet just before the turbine... an 8cm2 is from what I know an A/R of 0.57. Unless somebody has different info...
Tomas
Tomas
I digress... the a/r ratio is the ratio of the housing's cross-sectional area divided by that section's radius from the center axis. The inlet diameter is a different story all together.
...anybody sure of the a/r for either the compressor or the turbine??
