Factory Captive cable ties
Old 02-09-2005, 02:40 PM
IceShark
IceShark's Avatar
Originally Posted by Porsche-O-Phile
Maybe you could epoxy it onto the threads? I know it sounds ghetto, but think about it - if you ever had to remove it (after the epoxy hardened) you could just "unscrew" it. You could probably screw it back on afterwards too.
Naw, that is way too much monkeying around and it would likely end up being a one shot deal anyway. Nylon nut would be much easier and effective if you are not going to go with the original style.
Besides, I'm not sure how much the nylon cable tie would like epoxy or if epoxy would even hang onto the nylon for long. And a normal cable tie is pretty hard to undo without ruining it.
Additionally, nylon isn't exactly the finest material in the world so the less you mess with it, the better. Ever seen an industrial bag of cable ties? There is a warning on them to the effect to not use the ties if the bag has been punctured. Why? The ties dry out and become brittle. So always keep your unused ties in a zip lock bag and add a little bit of water to keep the humidity high.
I don't know why manufacturers decided on nylon for cable ties in the first place, guess it must have been cheapest.
Old 02-09-2005, 05:23 PM
Laust Pedersen
Laust Pedersen's Avatar
I asked my mechanic (Schneider Autohaus) for some of those and he found some in a big catalog, which looked identical (re-lockable), but with a minimum order quantity of 100. That happens to be more, than I can stick on my car in the next 10 years.
The re-usable feature is something that prior mechanics seem to have overlooked, so most of them are just clipped.
So are you guys interested in buying what I don’t need? I don’t recall the unit price, but they were quite reasonable.
Laust
Old 02-09-2005, 05:29 PM
PCinDC
Rennlist Lifetime Member
PCinDC's Avatar
Laust or Dan: I need some of these too. If you could spare 10 or so of them, let me know.
Old 02-09-2005, 05:47 PM
Zero10
Zero10's Avatar
I'd bite on a few. They've all been cut on my 951.
I'd probably need what, 20?...
Old 02-09-2005, 05:53 PM
Jfrahm
Jfrahm's Avatar
If I could get, say, 20 for $15 shipped I'd take 20. I salvaged some from my parts car but they are old and brittle.
-Joel.
Old 02-09-2005, 06:06 PM
eclou
eclou's Avatar
Received 1,189 Likes on 582 Posts
I'm in
Old 02-09-2005, 06:58 PM
josephsc
josephsc's Avatar
Location: Albany, CA: celebrating 100 years of independence from Berkeley, CA
This sounds like a good idea for a group buy -- I would want to be in.
Old 02-09-2005, 08:00 PM
IceShark
IceShark's Avatar
Laust, why don't you take care of this little project. Just make sure the ties are going to work over the studs and are long enough before you go and order too many. The relockable feature really isn't all that important since you probably have a 50-50 chance that they will break trying to unlock them after a couple years of aging.
Old 02-09-2005, 10:08 PM
aribop
aribop's Avatar
Count me in for 20 or so.
Old 02-19-2005, 05:57 PM
Laust Pedersen
Well, I got some (=100) tie-wraps, but not re-usable, not designed exactly for this purpose and a little awkward to install, but they work and are far better than nothing.
I’ll sell the rest as 4 batches 20 for $12, all included. Just let me know via PM if you are interested.
Laust
Old 02-19-2005, 09:01 PM
IceShark
IceShark's Avatar
Laust, those are the standard stud mount ties. Something under a dime each when you buy a bunch. You need a nut to make them work right.
People can get those anywhere, it is the push on stud ties that are the problem to find. If I do another battery cable build I'll order extra ties from Germany. I'll sell them for a buck each with the shipping.
Old 02-19-2005, 11:10 PM
Laust Pedersen
Iceshark,
I was tired of waiting for my mechanic to get those I originally saw a picture of, so I bought these.
It is true that they are designed to be used with a screw, but since they are compliant and I chose the hole to be smaller than the outer diameter of the thread, they can be screwed on and used as shown without a nut.
But by all means do buy the “real ones” and offer them for sale. However I am satisfied with my fully adequate solution.
Laust
Old 02-19-2005, 11:44 PM
IceShark
IceShark's Avatar
Laust,
I understand the frustration ..... you wouldn't believe how many hours I spent on those damn ties.
But now that I have them sorted out, one may as well use the originals. It is a pretty small cost considering all the rest you need to pay for.
I'll keep sending them out with the battery cable packages and not short cut.
Quick Reply: Factory Captive cable ties
