When does stock 951 fuel pump need to be replaced? How much power?
Originally Posted by 9fitty1
...yeah...how much power until the pump should be upgraded?
I know this is a 6cyl, and a 3.0L...but I thought i would throw that out there.
Rocket Scientist
Originally Posted by RogueM3
This is a very stupid comparison to make and it might be way off...but on 3.0 m3 engines which are turbocharged the pump needs to be upgraded at 360rwhp.
I only replaced mine on the S2 when it was so loud that I couldn't stand it. I heard that these pumps can support upwards of 500bhp. These pumps are overkill for these engines.
Dal.
Dal.
Originally Posted by Bengt Sweden
It needs to be replaced now since it is almost 20 years old and can fail any minute.
And I always follow the rule of upgrading when changing .
Bengt
Bengt
I believe that the Bosch high-flow pump that LR sells is the Bosch 10208. I've found several charts that show it flowing in the neighborhood of 54gallons/hr (320lbs/hr) at 50psi. Unfortunately, I haven't been able to locate any numbers on the stock pump (Porsche 944-608-102-04). Does anyone have that data?
And I quote for chapter 20 of the Service Manual:
Checking fuel pump delivery rate:
1. Unscrew fuel return hose on pressure regulator and hold end of hose in measuring glass (volume: approx. 1500 cm3).
2. Pull off DME relay in central electric board and bridge terminals 30 and 87b with a piece of wire.
Let fuel run into measuring glass 30 seconds. Delivery rate should be at least 850 cm3/30 seconds. Replace fuel pump if necessary.
Being careful with the units this should correspond to ~190 lb/hr (at 2.5 bar), as the minimum allowable flow for the standard fuel pump. As I recall the standard injectors flow ~37 lb/hr each or 148 lb/hr total. In other words the fuel pump should flow at least 30% more (and therefore handle 30% more HP) than the standard injectors.
Laust
Laust
So already when you run the next size injectors 55lbs/hr = 220lbs/hr, the pump is the bottle neck. Especially since the injectors are rated at 3 bar where the pump will flow a little less.
I believe it is important to keep the 30% overcapacity to not get pressure fluctuations.
Bengt
Bengt
Also remember that the boost pressure gets added to the fuel pressure. If you run a 3 bar regulator and 1 bar boost, then the pump has to produce 4 bar which lowers it's capacity further.
