Need to get Hosed
Derek ya great !!!
I will check the hose tech website but I hope the silver line comes in black I really want to tone down
the look As I live in the land of fruit and nuts ( SMOG ****'S )!!!!
Ya know they say a pic is worth a thousand words :-)
Thanks so much for all your help
Regards
Ed
Regards
Ed
The 4mm hose from HT fits very tight on all the fittings. 20 feet is more than enough. When i had the lindsey kit of 25 feet, i replaced all the washer fluid lines as well, since i had so much left over,lol.
Just thought I would add that I am not pleased with my HT hose. It has split a few times and it is generally flimsy. I am planning to get the mercedes plastic like hose that Laust uses. It isn't pretty but I could care less.
Max
Max
I'm unable to view those attached jpg's... is there a trick to it?
I get this:
It's not really a big deal, but sure would like to see what all that looks like since I'll be doing this on my car very soon.
I get this:
mattplatts, you do not have permission to access this page. This could be due to one of several reasons:
Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
Max
That's amazing I thought silicone was not suppose to crack !!
What was the dia hose did you used ?
regards
Ed
Max
regards
Ed
Ed - if we don't get a response, I'll try to measure them when I get home tonight, or tomorrow morning. I've got the head off and can see the WG pretty easily - I think I can reach it from above without too much of a stretch right now... just not sure if I can get a caliper on it.
I know it's got LR blue vacuum hose on it right now, along with zip ties. I didn't install it, so I don't know if they are a tight fit or not. The current hose is 4mm.
