Wire Connections (for engine sensors)
Will these work ? Seems like the best price out there - $14 for 8.
http://store.summitracing.com/partde...ctor+connector
Those look very similar to what i have. A fuel injector clip is a fuel injector clip, so it shouldnt matter too much. And those ends looks like they seal up, so you wouldnt need a boot.
Hey Bret, if you build that harness over the weekend let us know how it turns out. I'd like to see how it turns out as I'm planning on doing this too (or buying one from you)
John
John
UAE Rennlist Ambassador
Doc: I just looked at the fuel injectors, all look like new and feel soft and good.......(phew)
The ISV, knock sensor and TPS are hard and their boot covers are torn.........
They have ALL been sealed up with clear silicon which does the job..........for now........
The ISV and TPS are my concerns since they were in worse condition than the ref sensors (which are alright though)...
I wonder if a fuel injector connector would work on the ISV, i believe it might. The TPS connector will probably need a new connector and need to be respliced. I know mine is bad as well, dont know where to get it though other than porsche....though i havent looked real hard yet either. Man wouldnt a brand new wiring harness sound really good right about now
Used in good condition would be an alternative, plus some wire wraps would help out!
