High-pitch whistling sound from engine?
That Guy
This seems a little out of place... But i had a similar problem like yours,it was a squeak or whistle would come then go. Turned out that it was my A/C compressor bearing. It finally grinded away one day and a ear piercing squeal came from my car and it wouldn't run. Had to replace the whole A/C compressor (400$). Just a heads up in case thats your problem... Sounds a lot like a vacuum leak though.
-Ian's 2 cents
-Ian's 2 cents
nosurlife (04-25-2023)
Originally Posted by BoostGuy951
I have had that kind of whistling happen before, and it was a vacuum leak in the manifold. One of the little vacuum nipples between the runners had partially broken off.
lol he said nipples....
Hello again,
Here's an update. It was the heater valve (it is close to the firewall). My mechanic replaced it and the whistling is gone... I have the old one in a plastic bag, and may take a picture and post...
Cheers
Cheers
