T04E/T3 57 trim turbo
Originally Posted by dougoh
i bought a TO4E turbo from 55lbs injectors and new custom chips from guru and i was told 350 rwhp and if i were to go with a map kit i could get close to 400 rwhp
For a street setup, TonyG is the only one I know of who made that kind of power on a 2.5L... and he didn't just have a MAP and a turbo...
-Randy
you guys are expecting too much power.
especially at that boost level.
maf + chips + turbo + fpr + EXHAUST + tial + 55 lb @ 18-20 psi
will get you to about 310 - 335 rwhp (a lot depends on the turbo)
that is just my experience.
I had the 27/6, I personally loved it for a street car.
Now that it sucked in rubber and killed the trim
I bought a t04E/6 with a .50 trim from rob off rennlist
(I think it should have a little more aggressive top end)
but my tuning was so poor I couldn't tell
(It's in the shop getting fixed and tuned)
when it get's back I will be going to the dyno
I have all the above mention things + vittesse (instead of weltmeister chips) + t04E/6 + A/C delete
I'm hoping for the same amount of power at lower boost.
I try to be realistic about the power it makes and each time I go, and I am never disappointed.
Originally Posted by special tool
I made 405 RWHP wth stoc EVERYTHNHG. Ya gots ta have the right turbo, timing and MAF calibration!!!
emwporsche
I will be close to 400rwhp at those levels
Originally Posted by ECUdooberhead
I'm going to have to call bull**** on that one. You would need bigger injectors than #55 first off to make 400rwhp. Second... you would need to run 22-24psi (assuming you have a .50AR or so on that T04E).
-Randy
-Randy
as I recall you just rebuilt your engine, you have 75 lb injectors, msd ignition, and headers or cross overpipe?
they aslo are wanting a bolt on turbo, If I remember right your's isn't
a 60-1 could surely get them there but it doesn't really just bolt on
and I am assuming they want pump fuel with their 16 psi
I just don't want all these guys to spend a ton of money and end up all pissed off about only getting 300 rwhp
Originally Posted by emwporsche
as I recall you just rebuilt your engine.
Mercedesben,
For that T3/T4E 57 trim to be bolt on.
They have to sell you the turbo with a replica KKK housing.
A standard T3 flange is not the same as the KKK.
And if they do sell it with a kkk housing. Make sure its a stage 3 wheel. Thats what most people run.
And since you are buying new. I suggest a 50 trim.
Its got better low end and better top end compared to the 57 trim. Compare the data on the map for yourself and see.
http://not2fast.wryday.com/turbo/maps/
here is my email from Danno....yes, I can map a chip for using the stock AFM. It will be similar to
a K27/8 at under 21psi. Which is the most the K27/8 is good for,
about 325rwhp with stock AFM, 360rwhp with MAP upgrade. The TO4E can
go up to 25psi for 360-370rwhp with AFM and around 400rwhp with MAP.
Daniel - yes it was 23 psi but don't forget - I don't bull**** like a lot of kiddies on ths site. Hell - there is one full of **** guy on here who said he made 375 RWHP at 15 PSI with a STOCK head.
So you made 360 at 17 psi? Why didn't you turn it up and make more power for a high number?
UAE Rennlist Ambassador
Originally Posted by Edman951
Mercedesben,
In order for the T3 turbine to fit, you'd need flanges. Even then, i'm not sure if the turbine housing is too big, too small on this one.
Secondly, im pretty certain (but not sure) that it is only oil lubricated and not water cooled, which shouldn't be a problem if you mod you cooling system.
Thirdly, the map for the 57 trim doesn't seem's quite nice (if i read it correctly).
Secondly, it's probably a #65 set of injectors not #55, are you sure about the injector sizes? double check on that, here is a general webiste for calculating injectors:
http://www.holley.com/HiOctn/TechSer...l/Artcl07.html
Originally Posted by Mercedesben
I am running a stock setup, but will have a MAF.
I am hoping for a turbo capable of 330-350 rwhp
at 16-17psi.
at 16-17psi.
On thing you never mentioned is the way the turbocharger 'kicks' with regards to future upgrades. In other words, if you plan on doing some headwork, the #8 hotside would be a better option. If you are driving the car on the street and no plans for any upgrades with regards to the engine mechanically, then the #6 would be better, but get some custom work with the turbocharger down-pipe and a bigger exhaust to reduce the back pressure (though you might not choose this route, it's just my opinion here).........
"Hell - there is one full of **** guy on here who said he made 375 RWHP at 15 PSI with a STOCK head."
it was 1375 rwhp and it was at 5 psi
can't keep the facts strait can you?
hosrom
that is what was said in my email from danno....what i ordered from him was a TO4E turbo / 55lbs Delphi injectors and new chips...he calls the turbo a GURU-400 TO4E turbo (with matching water-pipe & temp-sensor)
